Old 03-26-2009, 03:13 AM
sideshow sideshow is offline
ive heard its common for the pressure ones to leak if the flares arent perfect
brake pedal switches on th epedal are only hard to fit if u get the wrong type
goto wreckers and look at which one will fit easy
easiest way is to pop rivet or weld a small angle iron on side of pedal
say half way along the depth of pedal cause if u try to work of the very thin front edge of the pedal u have limited room
so if u fit angle iron half way down then gives u more room to mount the switch along side the pedal
the handbrake switch is harder to fit than the brake switch heheeh
the metal on the hand brake lever is a bugger to drill
my website
www.sideshowsperformancewiring.com.au
