Old 03-26-2009, 10:55 AM
donraye's Avatar
donraye donraye is offline
Cobra Make, Engine: Street Beast "Grabber Orange"/Silver stripe w/418W 520HP full roller, T5. and: Backdraft #814 RT3B "Black Label" "Magic Black"/Sterling Grey stripe, 408W, full roller, 475HP, T5
Default At 10 degrees advance
Originally Posted by Cobra #3170 View Post
Check your ignition timing if have not already done so, retarded timing will really heat up exhaust manifolds in a hurry.
What I did with the timing was to find TDC on number one.( I also confirmed that by the crank/cam key positions before I put the damper on.) Then I installed the damper which was pointing to 0 degrees on the timing cover pointer after installation.
Then I gently backed the engine up (rotated it counter clockwise by the crank snout) until the damper was reading 10 degrees before that 0 mark on the damper.
Thats where I stabbed the distributor with it pointing to the number one terminal with the rotor.
That should be 10 degrees advance should it not?
I also just pulled a couple of plugs and they look normal, not light , gray, or white.
D.
