Old 03-26-2009, 12:50 PM
danc30's Avatar
danc30 danc30 is offline
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
Wow, lots of great info here. Thanks everyone.
Night Enforcer-
Approx 1200 miles on the plugs,
Initial timing is either 18 or 22 and the total is 38. Keith said the total should be 38 all in. My dyno tuner also said this was good.
93 octane pump gas (contains 1-10% ethanol)
1 can of Klotz octane boost per tank (1 ounce per gallon)
RPM Performer intake
10.5:1
QFT 950 DP
Camshaft Comp Cams Custom Hydraulic Roller - Duration 248/252 Lift .630 Lobe separation 110
Idled for about 1/2 mile in my neighborhood to get to my house. Revved once before shutting down.
MSD 6-AL w/ MSD billit distributor
I took the plugs ut last night and replaced the cap. If the system doesn't pressurize again, I will flush it and re-fill. I will then do a collant sytem pressure test to see if it holds.
What pressure should I pump it up to?
Oil dipstick looks fine, just changed my oil 150 miles ago and no coolant in it.
No exhaust smell in the air escaping the cap when released.
Dan
