Old 11-09-2001, 11:50 AM
anil anil is offline
If it's either 9.3 to 1 or 9.5 to 1, and (assuming) you're using iron heads, then I highly recommend you stay with 93 octane. You should be able to get by with less, but as we all probably know, gas is not perfect and I don't think you'd appreciate the detonation, which you probably couldn't hear anyway.
Also, compression ratio alone will not tell you what fuel to use -- smoothness of surface and sharp points will cause hot-spots that may require higher octane fuel.
Besides, it's a Cobra -- how do you think it would look if you pull up at a gas station and reach for the 87-octane pump?!
-Neil.
-Neil
CMC Cobra
Vortech-supercharged 5.0 EFI.
www.avn-tech.com/iac107/images/MEMBER_AN_cobra.jpg
