Old 03-28-2009, 06:51 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Bulbs to LED's ???
Now thats a different issue...
The stock flasher unit is a thermal switch...
LED's don't pull enough current to trigger the thermal switch...
You need to swap-out the flasher unit to a LED compatible design or add resistors in the back of the car on the indicator wiring...
Maybe I should make up a detail with part numbers and add this to the wiring diagrams?
SPFWiringDiagrams@Comcast.net
