Old 03-28-2009, 08:31 AM
wideglidejoe wideglidejoe is offline
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
Default Thanks to everyone!!
Thanks to all for your replies!
Clois???? posting at 5:51 a.m. on a Saturday?? Man, you are serious about this!!!
Seriously, thanks to everyone for the great info. I now have everything gathered up for my FE except for buying the Edel RPM heads and choosing a cam. I've decided to use a D4TE block (extra webbing in mains) bored to stock 428 4.13 (sonic tested out excellent), Scat 4.25 crank, Probe I-beam 6.7 rods and Probe forged slugs. Full MSD ign, Edel RPM intake, Holley carb, Edel alum water pump, Comp Cam roller rockers, Canton oil pan, etc, etc......all on ebay!!
Cam: I'm old school, leaning towards a solid flat tappet. Probably Comp Cams, and adding the nitriding treatment. I realize with the stroker that I won't turn the high RPM's the solid is capable of, I'll probably chip the MSD for 6,200 or 6,400, I just like the sound of solids. Any suggestions on grind? I'm leaning towards a 112 LSA, .580-.590 lift, and too much duration!! Gotta have the lumpy idle.
thanks guys!!
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
