Old 03-29-2009, 02:20 PM
patrickt patrickt is offline
Originally Posted by 428street View Post
I had the original small half-pint black/mustard top coil and it is mounted in the correct location, horizontially on top of the intake.
OK, if that is an oil filled coil and you have it mounted horizontally then that's most likely the problem. If you want it mounted horizontally then you gotta go with the epoxy "High Vibration" off-road jobs. Oil-filled coils leave air bubbles when mounted on their side and either short-out or overheat (or both).
