Old 03-29-2009, 04:53 PM
dlampe's Avatar
dlampe dlampe is offline
Thanks a lot Jeff. That helps. I will not be running at any type of sanctioned event, just open track, Shelby events and other "fun" days. I'm just trying to be as safe as I can and I couldn't come up with a way to wire the dual mechanical switches.
I have the main battery wire, the alt. wire, the EFI main power wire, and the main power wire to the dash/fuse box. I have 2 mechanical switches in series. How do I make this work? If it goes from battery to switch, switch to switch, then switch to solenoid where the EFI and Dash power connect, where does the alt wire go? Where the battery connects to the first switch?
I realize this is confusing but don't give up on me yet. I'm trying to follow along.
High Maintenance Racing Team
Run & Gun 2003 - 2013
