Old 03-30-2009, 08:49 AM
Dominik's Avatar
Dominik Dominik is offline
Default a lot to read
Sorry, I didn't read all but this is a not so clever designed upright.
Mickmate is right:
„You see they slotted that upper bracket for caster adjustment which is unnecessary as the lower arms are adjustable and usually the uppers are too.“
Also, I would use bigger bolts to hold the lower balljoint bracket. I believe they are 3/8“. And the bolts should come from through the bracket to the upright. If you sleeve the aluminum upright you may be able to use a M12 threaded insert.
AMP has a better set, if I am correct.
Do your steering arms point outwards?
Dom
If I don't respond anymore, that's because I can't log in
