Old 03-31-2009, 06:09 PM
JCoop's Avatar
JCoop JCoop is offline
Cobra Make, Engine: Superformance, FRP460 Big Block
The problem is that the sleeves supplied with the replacement bushing kit for the QA1 shocks have 1/2" ID. So, even if I got new 12mm bolts, they would be sloppy in there.
I ended up buying hardened steel 1/2" bolts, (this time with no threads in the shear zone), and drilling out the stock shock mount holes to 1/2". The bushings are also Delrin, rather than hard rubber as the original bushings were. It should be pretty rigid, especially without the slop. I may have to set the compression dampening a couple of stops softer.
I'm just disappointed that the premier assembler of Superformance cars on Long Island let this kind of thing fall through the cracks. I'm not naming names...
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
