Old 04-01-2009, 10:03 AM
Buzz's Avatar
Buzz Buzz is offline
It looks the previous owner of 427Snake's car began extensive modifications to his body and chassis. The drivers footbox is removed, The one on the passenger side looks to be fabricated, there is fresh aluminum work in the pedal area and there are signs of cut fiberglass everywhere, including the rear corners of the hood opening where the aluminum plates are added on and use the same rubber bumpers seen on the wider 'glass pieces on CMC/Streetbeasts cars. It would be interesting to find out what exactly it is, though.
427Snake, if you're still following, what does the tag on the driver's side of the firewall say?
BTW, the CMC in the link I posted doesn't belong to me so the Cleveland/Windsor issue would have to be taken up with whoever the seller is.
Tropical Buzz
