Old 04-01-2009, 11:45 AM
427snake's Avatar
427snake 427snake is offline
Originally Posted by Buzz View Post
It looks the previous owner of 427Snake's car began extensive modifications to his body and chassis. The drivers footbox is removed, The one on the passenger side looks to be fabricated, there is fresh aluminum work in the pedal area and there are signs of cut fiberglass everywhere, including the rear corners of the hood opening where the aluminum plates are added on and use the same rubber bumpers seen on the wider 'glass pieces on CMC/Streetbeasts cars. It would be interesting to find out what exactly it is, though.
427Snake, if you're still following, what does the tag on the driver's side of the firewall say?
BTW, the CMC in the link I posted doesn't belong to me so the Cleveland/Windsor issue would have to be taken up with whoever the seller is.
Hi Buzz
There are a lot of modificatione on my car.
The aluminium is my work because the fiberglas work was very bad.
The jaguar rear end is not original. Somebody change the ford rear.
The Tag says CC-MCC(USA)
Vin SK8160PA
Replacement Identification Number SK8160PA
Control Number: 372530
state of california
departement of motor vehicles
Martin
