  #21 (permalink)
Old 04-01-2009, 08:09 PM
mickmate's Avatar
mickmate mickmate is offline
Talking Lets make sparks, me like sparks!
Wow there's some super feedback and info coming out already. The first car (Doug hold your horsepower) is John's SPF with a pretty rumpy 7 in it. He actually saved Deans post and info for a looong time to source his mufflers. He got them from Stainless Specialties here http://www.stainless-specialties.com/products2a.htm and I believe they were the Perform Master. The pipes we were putting them into were mild steel and they were getting ceramic coated so there's no need for stainless here but the results were unquestionable, read on. The SPF use the flange to flange for a header sidepipe connection. John and others say it's a bear to get at some of the bolts there's a thread on it in the SPF section on CC. With this first set of pipes I lined them up with the edge of the welding table, tacked some washers to the bench that were bolted through the flange so I could accurately relocate the parts relative to each other. Then I measured the length and tip height of the tail pipe or dump tube. Take a minute to know for sure that you can get back to where you were. There's better methods coming so hang tight. At this point we unbolted it from its makeshift fixture and ceremoniously cut the old muffler out with a chop saw. It worked out really well having the new muffler 1" longer. That gave us a nice clean cut and piece of tube to work with instead of cutting right on a weld and trying to clean that up without losing any length. I obviously recommend an extra inch as the actress said to the bishop! Having adjusted the lengths and squaring up the collector tube and tail pipe they were cleaned up for welding. Next the parts are realigned back on the fixture carefully with the mount being relative to the flange end. At this point they are tacked together in at least 3 spots. Check it all again to make sure nothing has moved and weld the parts together. If you're using MIG to weld stainless to mild you'll want a 308 wire and Argon backing gas. We used the TIG to tack and weld. Interesting to note with a job like this most of the time is in the set up and prep. By the time it comes to switching your MIG over and paying for a spool of wire etc it really was quicker and easier to TIG them. The TIG welds are a whole lot nicer than the welds I'm seeing on all these factory pipes done with a MIG. Ceramic coating covers some sins but the MIG welds have got holes and inconsistencies in them that the ceramic coating doesn't hide. A good MIG welder would do a bang up job on these I'm sure and they are really good for filling in dents and disc pad sanding them back before coating. Most of these pipes suffer a little underbelly roadrash. I'll show you guys what we saw side by side on the old and new mufflers. Stay tuned
mickmate
http://www.actoncustom.com/
