Old 04-02-2009, 12:39 PM
blykins blykins is offline
You should be able to tell the difference between thick gear oil and motor oil. If you can smell it, you'll know which one it is.
Toploaders will leak from around the shifter cams because there are o-rings behind each one. It is very well possible that it's leaking from there.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
