Old 04-03-2009, 02:43 AM
stephen low's Avatar
stephen low stephen low is offline
What engine mounts are you using Greg?
I was pointed at quite early, XY I think, mounts but then I had original AU mounts that were horribly tall.
Also the AU variant 302 needs continous flow in the water pipe loop for a sensor so this is done pre-heater so that if you want to switch off hot water you can and avoid continuous radiant heat into the cockpit.
And who knows you might want to make a trip into Canberra where you always need a heater or even Melbourne on an off day!
slowy
