Thread: Cam bearings
Old 11-11-2001, 07:41 AM
kingair kingair is offline
Club Cobra Member
Cobra Make, Engine: ERA#389 427 so, gone to N.J./ Superformance "BROCK" Daytona Coupe SN 55
Sure did!! No oil pressure after put the new rocker arms and shafts on. As we discussed these are Shelby alum. heads and you don't have to worry about the bolt placement. While waiting for parts to come in we changed the oil and didn't think too much about any problem with that, but when started, no press. let it run for a few minutes and still no press. Pulled the V.C. Pass. side looked good and drivers side dry as a bone!! So much so that rocker arms were frozen on. At least I have good push rods and springs! We are going to do one more thing on Monday, pull the plugs and spin over with no resistance to see if oil comes up galleys. Before you ask, yes we poured oil over the new shaft assby. and thought that would be enough to last during the start up, don't forget this thing isn't new and has allways pumped 60 plus lbs. of press. Any thoughts are welcome. Kingair is grounded!!!
