Old 04-03-2009, 06:36 PM
madmaxx madmaxx is offline
Do not go with hydraulic throw out. All the cobras I ever worked on 15 plus had the external slave and worked perfect. Is your slave pushing perpindicular to the clutch are? Have someone push in the clutch pedal and see if it is pushing straight, not at angle. If it is GCPC has a bracket that will get i perfect. Your enemy is not heat, DO NOT USE SILICONE brake fluid. if you have that is your problem.
