Old 04-03-2009, 06:49 PM
Jimbocobra's Avatar
Jimbocobra Jimbocobra is offline
Cobra Make, Engine: Backdraft#357, 392CI Ford Racing, 459hp, 455ft/lbs , TKO 500, 3.43 Gears, Ceramic Coated Headers, Victor Jr. 750cfm, 17in Halibrand wheels, Sterling Gray/Silver Stripes, Gray Leather, Nitto NT05
Default Madmaxx
I am using Royal Purple. Not sure if it has Silcone or not. I will call my shop and find out. The slave runs parellel to the ground. When we replace the slave we use part of a rocker arm to allow the slave to go straight in and out but still have some play. If it is not heat, do you think it is the placement of the slave? The shop told me that they felt that slave was meant to push and it is pulling or vice/versa - either way, they did not like the set up.
