Old 04-03-2009, 07:18 PM
Jimbocobra's Avatar
Jimbocobra Jimbocobra is offline
Cobra Make, Engine: Backdraft#357, 392CI Ford Racing, 459hp, 455ft/lbs , TKO 500, 3.43 Gears, Ceramic Coated Headers, Victor Jr. 750cfm, 17in Halibrand wheels, Sterling Gray/Silver Stripes, Gray Leather, Nitto NT05
Default Heat
Bill,
I will order it and call you tomorrow. I sent you an e-mail as well. Just one question, if heat is not an issue, why does it only happen when it gets hot and when I am not moving, like at a stop light. At this point, I could care less about the $110. I just keep ordering parts and taking it to the shop and everything I try doesn't work. I believe you, just want to understand it the heat connection if it is an alignment issue? You have worked on more cobras than anyone in the country I suspect - especially BDR's so if this and the fluid change will do it, okay with me - I just want to drive it without worrying that I won't be able to get it into gear - takes the fun out of it.
I may also order the powersteering kit and a soft top in time as well.
