Thread: MSD 6AL missing
Old 04-04-2009, 03:40 AM
Default Are you still running the Webers?
Eljaro Are you stilling running the webers with this problem? How do we know it's not a carb issue? The timing change could be a loss of power? Is it possible that you are having a dirt issue in one of the carbs on the main circuit? Did we look at all the plugs? Color and gap? Sorry, we get so crazy going after electricial things we over look the basics first. There is no backfiring when the timing changes either through the carbs or the pipes? Did you check the timing chain play with a larger breaker bar for play? How many miles on the motor? Rick L.
