Old 04-04-2009, 06:50 AM
madmaxx madmaxx is offline
He has bdr 357, bill littleton is a BDR dealear along with Cashburn. Run of the mill TKO500 and Ford racing engine. I have no idea what would cause someone to install a pull type slave cylinder set up on his car when 99% of the bdr's use the bracket style Bill has.
I have worked on alot of cobras not by will, LOL!!! I am sure a 5 minute conversation will Littleton or cashburn dwarfs my experience which is fine, i just use what works. It is so frustrating to hear about these issues which remove pleasure from the Cobra experience when the solution is very very easy.
The only item which needs to be confirmed is you have the right clutch arm, i know you have the right bellhousing, transmission, clutch master cylinder.
