Old 04-04-2009, 07:43 PM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default How to Measure your Coolant Voltage
Gents, The protection you need to minmize electrolysis is ensure all of your grounds are well established on the chassis and each electrical consumer is properly grounded . If the radiator is being used as the path to GROUND, the current or potential (voltage) can be checked in the coolant. I went to Griffin's Radiator web site and found this helpful how-to. Dont just guess if electrolysis is an issue for you, measure it, this method works from experience. Here is the link below.
http://griffinrad.com/electrolysis.cfm
"...some assembly required, ages 8 and up...... well that took longer than expected......
