  #26 (permalink)
Old 04-05-2009, 01:01 PM
mikeforte mikeforte is offline
Hi Jim,
I have a simple bolt on slave fork assembly for the TKO aluminum bellhousing.
Why it fails when hot could be several reasons. To much heat on the master cylinder or hydraulic hose, failing slave or master. Any leaks?
I would need to inspect everything to determine the actual cause but it must be obvious
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
