  #30 (permalink)
Old 04-05-2009, 06:20 PM
madmaxx madmaxx is offline
I drove my spf 80 plus miles, put it up on the 4 post and my slave was cold to the touch. For brake fluid to boil you have to be at 401F, rest assured noyone is getting that hot. Talk to bill about the silicone, you should have never put that stuff in, i assume you can flush your clutch master cylinder with no ill effects. Silicone is designed for classic cars which get driven very very rarely. Google it, since water does not emulsify in it it readily boils, however it is good for paint since it does not deterioate it. Just use the run of the mill preston dot 4.
