Thread: Cam quest
Old 04-06-2009, 09:02 AM
undy's Avatar
undy undy is offline
Originally Posted by sparks View Post
Checkin with bill at SA to double check on the cam specs , but the guy at demon thought my duration seemed a little much. Durration ? This is all so confusing.
It's not only how deep your valve can go but how long you can keep it there too..
If you're bound and determined to run a flat tappet cam ensure you remove your inner springs for break-in. Your cam lobes going away are a real and present danger at break-in .... and past break-in for that matter. The major engine builders are even plagued with this problem, hence the hydraulic/mechanical roller.
