Old 04-06-2009, 12:30 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
look for the t-stat being bypassed with heater hose or the plumbing configuration somehow. Easy test is feel top rad hose from cold start up, is temp cold till t-stat begins to open or does temp come up before hand. With a cold system you should be able to feel where heat is coming from if you consider system as 2 sides. 2 sides are those on each side of t-stat and should be that cut n dried.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
