Old 04-06-2009, 01:49 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is online now
Originally Posted by Wayne Maybury View Post
The engine is designed and probably built to run at 180 to 190 degrees. Operating it for an extended period of time at a temp well below 180 means that the tolerances are not correct. For example the pistons are aluminum and the cylinders are steel. The 2 expand at different rates with the change in temperature but are machined to operate at 180 not 140 degrees.
As a rule of thumb, your engine sustains more wear in the first 5 minutes of operation than it does in xxx miles (sorry, I can't remember the number of miles).
Wayne
I had to replace my thermostat and the closest engine catalog listed a 195. Mine was 180. Any advantage or disadvantage in going higher?
