Old 04-06-2009, 07:35 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
There should be air in the line. Actually, if you have oil in the line up to the gauge you have a problem. That gums up the gauge and actually could be your root problem. Usually if the fitting on the gauge is not properly sealed the air cushion will escape from the line and the oil will reach the gauge...
SPFWiringDiagrams@Comcast.net
