Thread: Tremec Noise
Old 04-07-2009, 07:35 AM
madmaxx madmaxx is offline
if you must, determine the number of teeth on the 4 th and 5th gears, then have a vibration teck ride with you, he will tell you in minutes if it is in the trans or rear end, bearing etc. problem is you have to have access to the vibration tech, may want to look at junior colleges if you do not know someone in industry.
