Old 04-07-2009, 11:19 AM
lovehamr's Avatar
lovehamr lovehamr is offline
Stolen Avitar
Originally Posted by RICK LAKE View Post
lovehamer Steve is this the right part for the car?? Companies have boxed stuff wrong before? Are you running a windage tray? Rick L. Ps what numbers stamped on the pan?? Did you call Moroso about this?
The pan is definitely an FE pan, no windage tray, it's going in a Cobra with no cross pieces under it so I didn't even have to use a front or rear sump. If you would really like the #s I'll look when I get back home. In the rear the factory bolts sit almost flush with the main cap; the ARP studs with nuts protrude above (or below depending on how you're looking at it) that level enough to hit the back of the OP where it curves from the pan rail. As far as calling Moroso goes, no I haven't and probably won't as I bought this thing used from one of the guys over on the FE forum and at any rate it's for a factory FE and probably wasn't designed with ARP studs in mind.
Steve
