Old 04-07-2009, 12:44 PM
undy's Avatar
undy undy is offline
Originally Posted by Wayne Maybury View Post
Lots of good feed back here but if this was my car, I would change the thermostat before doing anything else. It is quick, easy, and cheap. You cannot make it worse and if it doesn't fix the problem, you have eliminated one factor that hasn't cost much. I think that the present thermostat isn't closing properly so you are getting coolant flow when you don't need it.
Wayne
Pull the t-stat and put it in a pan of water on the stove. Stick a candy thermometer in it and turn the heat up. See what it does.
