Old 04-07-2009, 05:48 PM
CarsByCarl CarsByCarl is offline
When using 75cc heads:
9.25:1 will require a -20cc dish
10.25:1 will require a -10cc dish
Flat tops will give you approx 10.7:1 if left in the hole a bit, which can work with alum heads and pump gas.
There is unfortunately a very limited selection of off-the-shelf 429 pistons available if using a stock rod.
Stock cast replacements like the Silvolite 1161's have a -12cc dish
KB offers hyper flat tops
Speed Pro offers forged flat tops
Other than that, you'll need a custom
You can use 460 pistons with the 429 crank and aftermarket cadillac rods if you're willing to do a little work on the rod bushings.
You can also use a 460 crank, the rods you have and 460 pistons.
CarsByCarl.com
Ford performance engines
Now on the web! Just click the link above
