04-08-2009, 01:35 PM
MO
Cobra Make, Engine: SPO 2715
Originally Posted by McDoo
Eric,
Fuel Safe has a custom tank that is configured to
fit the SPF in the same location as the factory tank. It is slightly wider than the stock tank so you need to do some fiberglass trimming in the inner fender area to fit it. It is Tig Welded aluminum with a sportsmen pro cell bladder. It
looks much better than the stock tank when installed, like
a polished SST tank. You should give them a call if I remember correctly it is somewhere around $1100.00. You will gain a few gallons of gas but gain a ton on safety
Mcdoo
Pictures, I need pictures!!!
E
