Thread: cooling system
Old 04-10-2009, 09:18 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
I would probably clean everything up with "Simple Green" and watch it.
If you recently replaced or topped-of the antifreeze you may have overfilled the system and the leak you see may only be the system looking for equilibrium...The expansion tank should only be filled up to the hole in the tank divider inside with fluid...put you finger inside the tank and you can feel the hole in the divider.
SPFWiringDiagrams@Comcast.net
