Old 04-12-2009, 04:37 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by Rwillia4 View Post
I purchased a standard lokar cable. I also called TWM (http://www.twminduction.com/Home/Home-FR.html) and order a adjustable screw on end piece. Works great no problems.
To install it I found it is easier to remove the middle piece this fits into, it is three screws, then slid it out the back. Once I had it back together I was able to adjust the cable length (with a long screwdriver).
Which Lokar cable has the right end? There is a guide tube the cable has to go through on its way out of the engine under the fuel rails, so no end protector can go on it before installing it.
