Thread: Jag Rear
Old 04-12-2009, 04:53 PM
david dickinson david dickinson is offline
Cobra Make, Engine: southern roadcraft (UK) 350 edelbrock performer rpm
Send a message via Skype™ to david dickinson
hi there i have a jag rear end on my car and one thing to check before you pull it apart is ,make sure its not free play on the lower fulcrum bearings as this will also give rocking movement when you shake the wheel. However if it is the wheel bearing ,all you have to do is remove the hub from the driveshaft and remove the lower wishbone keeping safe the bronze shim between the driveshaft and hub bearing.Removing the bearing and replacing is best done using a hydraulic press to avoid damaging the bearing or damaging the hub carrier .When you replace the carrier it is important to check the end float on the shaft after tightning (100 lbf ft). cheers Dave
