  #41 (permalink)
Old 04-13-2009, 05:45 PM
madmaxx madmaxx is offline
All cars grind going into reverse, what about the forward gears? To prevent grinding going into reversre the solution is simple, shift into third first then reverse and it will never grind. so first push in clutch, shift to third, then while still holding the clutch in shift to reverse.
Are you saying it shifts fine in the forward gears when hot and cold and the only perceived problem in reverse?
