Old 04-14-2009, 06:23 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
I have a few question regarding the dynatek system vs true Weber carbs. There is no doubt about haveing the Weber carbs properly tuned is a true accomplishment. However, properly tuned can mean many things to alot of people. I have had my Weber carbs for sometime know and do wish sometimes that I have purchased the efi setup. But when you sart caomparing the dollar amount between the dynatek and Weber carb there is a huge difference.
Weber carbs = $2500
dynatek = $6000
We are here arguing if the efi will give you more HP compared to the carb setup and can not come to an agreement nor will dynatek comment if you will gain more power from there system.
If I were to use the dynatek system I would definitly through out the computer and use the Halteck system. This is just my opinion. However, I dont think you have that option.
The only down side I see to the Weber carbs besides the cost to properly tune them ( which I have managed to help someone tune their weber setup for approx. $ 100) is the fuel drip that happens after shutdown.
The Weber carbs are period correct and alot of fun to play with.
But bottom line, the dynatek system is for different people than the Weber carbs.
But the HP out come from the dynateck will definitly not justify the cost difference.
