  #31 (permalink)
Old 04-14-2009, 06:45 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
The pilot bearing to input shaft nose is either too tight or the bell housing alignment to crank centerline is off---the syncros stop the trans shaft from spinning for forward gears but reverse doesn't have that---these new modern trans are much freer turning, especially when warm and the trans imput shaft is turning from induced friction from the pilot bearing----the older style bushings didn't do this very often but the new very tight fitting roller bearings do.
