Old 04-15-2009, 11:20 AM
RodKnock's Avatar
RodKnock RodKnock is offline
Originally Posted by Got the Bug View Post
zzmac,
Does your engine have any drips at all? If so, you may experience an increase in drips/leaks using a synthetic.
For me, it just seems to make more sense to run a conventional oil vs. a synthetic. I guess I would consider it if I was going to regularly track my car, but conventional oil and frequent oil changes fit my maintenance routine.
I agree with Doug. I ran Redline synthetic for a few hundred miles early on, but then I switched back to dinosaur oil. While my oil pan did have an issue, which is now corrected, I went from a few leaks to zero leaks...knock on wood.
However, if I ever go back to synthetic, then I would use Redline again. It reportedly has one of the highest ZDDP (zinc) levels in the industry and the company is located right here in the SF Bay Area.
