Old 04-17-2009, 05:49 AM
undy's Avatar
undy undy is offline
Originally Posted by StreetSnake View Post
Thanks for the information. That makes sense.
Another thing Street.. Most of the US is still on "winter blend" fuel. That fuel has a much higher "vapor density" than the "summer blend" stuff. That means the fuel is much more prone to flashing off at lower temperatures. Under cold weather conditions that's a good thing... but ... when it warms up outside it can be a real pain in the arse. Now you have fuel that wants to "vaporize" in your fuel lines, as well as you intake tract/combustion chamber. You can check with your local gasoline suppliers to find out if you're still on the winter blend stuff. Believe, me, that can make a SIGNIFICANT difference.
Dave
