Old 04-18-2009, 11:44 AM
Rick Parker's Avatar
If the balance of the engine was built for track usage such as intake, heads, cam etc you may find a vacuum secondary carb to be a huge compromise. One of the main reasons the HP and DP use more fuel comparatively speaking is because the idle circuits are dictated by the metering plates and their idle feed restictors which are intended to be much richer. Changing the main circuit jetting only limits the MAXIMUM fuel that will be allowed to flow. Do some research and check out the carb that was on the 425 HP 427 Chevrolet from the late 60's. The Metering plates control the show. You could contact a noted carb tuner such as Brasswell or Sean Murphy Induction and have the existing IFR's reduced in size and keep the same carb.
Rick
