Old 04-18-2009, 09:10 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
I used the cork gasket on the ends. But I glued it in place with a thin coat of the black Right Stuff and let it sit over night. Also dabbed it into the corners where the intake gasket and the end gaskets meet. Then with the Right Stuff again I glued the intake down on top of the cork. Just a thick enough bead to get squeezed out. I also used brake clean for a final cleansing before applying anything. It's important to make sure the distributer lines up before anything dries in case you need to move the intake to align it.
John
