Old 04-20-2009, 06:59 AM
BrianR BrianR is offline
Cobra Make, Engine: Classic Roadster 422ci 460H.P.
Default DV....Side pipe question
I built my CR back in 2000 and I still am so grateful to you for all the great technical support you so graciously gave to us back then. I must say I have just been driving my car since and have not been on the forums much. It is just great to see you still involved.
O.K.......back in 2000 you were replacing the muffler part of the original CR side pipe with something that had quite a lot less restriction and added a lot more H.P. I sent you my pipes and you did the mod for me which worked absolutely wonderful. At the time you gave me 3 options I believe....one was fairly quiet,2 was middle of the road and 3 was a serious bark. I chose the middle of the road option which sounds really good and does have a bit of a bark which I know a Cobra should.......although......as I get a little older I do believe I would like to tame it down a bit by making it a little quieter.
With all that said, my question is....can I make what I have a little quieter or do you have a set of side pipes you would sell that would be "fairly quiet" or.????
I now have the pipes you built for me chromed. I don't really care if I loose a little horsepower. I have a 351W bored and strocked to 422c.i. with 460 h.p. and 500 ft lbs of torque on the dyno so it is plenty enough for this old guy.
I would very much appreciate your thoughts regarding options for me
Thanks, Brian
Little Falls, MN
