Old 04-20-2009, 10:32 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Brian,
Not without cutting one end of the pipe off and the cost at that point would be more than new "bullitts".
John...Of course I do! You think I'm old or something ?
If you are using CR's stock exhaust you can -will- gain at least 27 hp. at the wheels and close to 35 lbs of torque. Huge numbers for any type of single, relatively cheap engine upgrade.
John a company called (and located) "Arizona custom exhausts" used to make the side pipe bullitts for me. Kind of like a "cherry bombs" but not. These were steel lined made with innerds packed with burn out proof fiberglass cloth-straight through, no restrictions and actually a little narrower than CR's stock pipes.
A.C.E., sold out and the owner retired.....that's the last I remember/heard of them.
DV
