Thread: 50 w oil
Old 04-21-2009, 02:56 PM
strictlypersonl strictlypersonl is offline
The only time I would use a single-weight oil is for an industrial engine or a compressor. Multi-viscosity oils work much better than 30 years ago, and with the tight clearances in a street engine, you risk running dry until the oil gets up to working temperature. Cold 50W will also strain the oil pumping system at low temperatures because of the ultra-high backpressure from restricted cold flow.
