Old 04-22-2009, 07:55 AM
tboneheller's Avatar
tboneheller tboneheller is offline
Cobra Make, Engine: E.R.A. #505
Originally Posted by jdean View Post
I've had both 8.8 solid and IRS. There is zero difference internally.
The axle gears are different, but you won't be changing those. You are supposed to you a case spreader when remove/install the carrier. I have done thousands of these over the years without one when I worked for Ford. Buy a good quality gear set & do it right the first time. I have not had good results from the stuff from Richmond Gear (make noise). Get a factory Ford or Ford Racing set.
