Old 04-22-2009, 06:45 PM
vector1 vector1 is offline
Cobra Make, Engine: jbl
drilled thermostat won't help the cooling, just helps keep temperature spikes down and allows the bleeding process to go smoother imo.
hood scoop will not ventilate the engine compartment, that is my point. why is the engine compartment criticized for poor air flow if the wheel wells are open, something else restricting movement?
overdriven water pump? wouldn't be cavitating would it? is this normal setup?
