Old 04-22-2009, 11:33 PM
STEPHEN BROHOLM's Avatar
STEPHEN BROHOLM STEPHEN BROHOLM is offline
Cobra Make, Engine: Still dreaming!
Default Indicator and brake light issues (for the Darksiders)
Hi guys.
I have a drama that isn't Cobra related, however with all you Darksiders out there I'm hoping one of you gents might just have the answer.
I'm currently driving the boss's VZ - S Ute whilst he's overseas, and am experiencing some issues with the indicators and brake lights.
Yesterday afternoon I'd noticed that the indicators both externally and upon the dash do not work at all. In fact the left and right turn signals don't actually have any typical clicking sounds (no noise at all) coming from the flasher "relay-can" built within what appears to be a Body Control Module.
When I select the hazards, the hazard "relay-can" is audibly clicking on/off as normal, however none of the indicators operate either.
The indicators still don't flash when I lock/unlock the vehicle via the key fob, however what may be the hazard "relay-can" still makes an audible noise as expected.
The brake lights are also not functioning at all.
I've metered all fuses located within the harness in the engine bay, with them appearing to be ok.
Can the problems I'm experiencing be related to the Body Control Module? I'm hoping to find a solution asap to reduce the risk of driving without indicators and brake lights.
Thanks in advance.
Steve.
