Old 04-23-2009, 04:52 AM
A98Coupe's Avatar
A98Coupe A98Coupe is offline
Cobra Make, Engine: #535 Kirkham 427, 427 Side Oiler
Hi-Tech Cobra,
Just picking up on the comment you made about the hose connections between the SW 240's and mechanical pump
"Two feed lines running down the drivers side. One to the mechanical fuel pump (Robbmc 550hp), and the other from the electrics (240-A's) up to a T above the mech fuel pump."
I always thought that the electric SW pumps were connected in parallel and fed directly into the mechanical pump? But you are running them separately - Is that correct? Or do you have a reason to do it that way?
I'm asking the question because I'm about the connect up my SW pumps and planned to feed them into the mechanical pump.
